Will GTX 750 TI fit
The gtx750ti will fit, but you need double check or to do;
1) The PC will come with low wattage PSU, check it out, you will need 400W PSU for the gtx750ti. https://forum-en.msi.com/faq/article/power-requirements-for-graphics-cards-20
2) Check the MB BIOS version, if it does not have newer one , check Acer site to see they provide the newer BIOS or not, because the MB will need the newer BIOS for the new hardware.
3) Check out the info from Nvidia support: http://nvidia.custhelp.com/app/answers/detail/a_id/3156/~/when-installing-an-after-market-graphics-card-into-a-certified-windows-8-pc so go into the BIOS to see the BIOS has those features or not.
Good luck.
Good luck.
MERGED QUESTION
Question from xpguys1 : "Help with Msi GTX 750 TI"
I got a 250 w psu you think i could pull it off ?
