Will GTX 750 ti work in my system which Has PSU of about 290 watts?
farhatuddinsml
14
I wanted to know if gtx 750 ti will work on My pc ... having 290watt power supply and its has no pci e connector. I use dell optiplex 9020
Code:
The Dell PSU won't be an issue. They are very conservatively rated. Aftermarket PSUs tend to overstate their power ratings, but Dell business customers want low power comsumption. A Dell 305W PSU when tested earned a 400W rating. Aftermarket uses Peak Watts. Dell uses a continiuos rating.
95W CPU + 75W GPU= 160W. That leaves 130W for the little stuff.
https://www.hardwareinsights.com/dell-h305p-01-power-supply-review/2/
Ohh 🙁 .. sorry.. by mistakenly i have downvoted your comment.. i cant undo it..very sorry :/ .. The Model name of my PSU is dell RVTHD ..model no= H290AM-00 .. I am going to get the GTX 750 Ti 2GB version.. please reply 🙁
Ohh 🙁 .. sorry.. by mistake i have downvoted your comment.. i cant undo it now..very sorry :/ .. The Model name of my PSU is dell RVTHD ..model no= H290AM-00 .. I am going to get the GTX 750 Ti 2GB version.. please reply 🙁
Is your Optiplex 9020 the MT version or SFF? If you aren't sure. which computer does it look like from this photo (left or middle).
If it is the SFF version, the best GPU you'd be able to get is the GT 1030, as the PCIe x16 slot is power limited to 35w. If it the MT version the PCIe x16 slot supports the standard 75w, allowing for a GPU as high tier as GTX 1050ti. If that is the case the 750ti would also work.
Looking at your PSU wattage, it seems to be the MT version. It seem to be compatible, just make sure the GPU you get is below 16.7cm, and install the GPU to the blue PCIe slot (not black).
From the url image.. its the left one.. the big one .. I guess i have the MT version 😀 .. So you are telling me that i can run a gtx 750 ti 2gb version on my pc ? without PCI e cable ? 😀
As long as you get one which doesn't require a 6 pin PCIe connector (if it doesn't have port). Also, the GTX 750ti's right now are overpriced. You could get a much better performing card in most scenarios for the same price. What is your budget and location/retailers purchasing from?
Oh.. i see.. isnt gtx 750 ti .. without PCIe cable ?.. Which card can i get that is better than 750 ti ? My budget is around 130 USD ... I live in oman,muscat.. I will be getting it from a shop know as EMAX
some DO require a 6-pin, so buyer beware
the 750 ti is obsolete, a gtx 1050 should be around the same price and is a lot better.
Just make sure to buy a version that does NOT require a 6-pin from the power supply and it should run
they are ~75w cards that run on the power from the pcie slot alone =)
Make sure to get a small sized one!
Oh I see .. is this the one you are talking about ? https://www.amazon.com/EVGA-GeForce-GAMING-Support-02G-P4-6152-KR/dp/B01M64G435 .. and this runs without pci - e cable ?
1. the power requirements for a GTX 1050ti (no 6pin) is 300w
2. the power requirements for a GTX 1050 (require power connection) is 300w
3. the power requirements for a GTX 750ti is 300w
technically speaking, you will be stressing your power supply, can you do it, sure, will you be looking for another power supply in 6 months... my bet yes.
why dont you just upgrade the power supply to a 500w and get a nice 1060 or a 980ti?
if you click on the 6th picture you can see the empty outline of where the 6-pin connector would go
=) yes that card does not require a 6-pin
+1
since your computer has an i5 this would be the best possible card you can get without changing your power supply
the gtx 1050 ti is a good card, if it can fit your budget
I thought even the gtx 1050 OC version is without 6 pin
i would have upgraded my powersupply but just want to use the 290w one for now
oh damn .. 😱 .. cant i just get the non titan 2gb gtx 1050 ? wont that work?
Oh ... Gtx 1050 .. (non titan) ?? wont that be fine ? ..
the gtx 1050 is a good card, if that is what is in your budget then go for it
