P Prangy Reputable Aug 3, 2014 9 0 4,510 Jan 28, 2015 #1 Will the Gigabyte GeForce GTX 960 ITX OC 2GB fit an H57H-AM2 motherboard?
Solution bignastyid Jan 28, 2015 Well the motherboard seems to have a 16x pci-e slot and that card fits into a 16x pci-e slot, so I'd say yes it will fit into the board.
bignastyid Titan Moderator Jun 19, 2011 33,688 1,700 159,590 Jan 28, 2015 Solution #2 Well the motherboard seems to have a 16x pci-e slot and that card fits into a 16x pci-e slot, so I'd say yes it will fit into the board. Upvote 0 Downvote Solution
H Harumph Distinguished Sep 16, 2010 5 0 18,510 Jan 30, 2015 #3 It will fit. The board has a PCI express 2.0 slot whereas the GTX 960 can go in a PCI express 3.0 slot. However, PCI is backwards compatible so the GTX 960 will work. In a single card configuration you shouldn't really notice any potential drop in performance: http://www.tomshardware.co.uk/answers/id-2141520/pci-express-x16-graphic-card-pci-express-x16-slot.html Upvote 0 Downvote
