Will h100i fit in my case
Hellmaster06
14
Antec 505 case details Dimensions: 200 x 485 x 465 mm (W x H x D)
Material: steel (Body), plastic (front cover)
Weight: about 4.8 kg
Color: Black
Form Factor: ATX, Micro-ATX, Mini-ITX
Fan total possible:
2x 120 mm (front)
1x 120 mm (rear)
1x 120 mm (right side panel)
2x 120 mm (lid)
Thereof pre-installed:
1x 120 mm (front, blue LED)
1x 120 mm (rear, blue LED)
1x 120 mm (side section; Blue LED)
Filters: Front, Back, Power Supply (removable)
Drive bays:
2x 5.25 inch (external, tools)
1x 3.5 inch (external)
4x 3.5 inch (internal)
1x 2.5 inch (internal)
Power supply: 1x Standard ATX (optional)
Expansion Slots: 7
I / O panel:
2x USB 3.0 (internal connection)
1x per Audio In / Out
1x Lüftersteurung
Maximum video card length: 380 mm (without any waiver)
Maximum CPU cooler height: 158 mm
if you have space for 2x120 then you should be fine. I have the H80I GT, but the radiator itself is a little bigger than 120mm width/length. I had trouble fitting it into a single 120mm space. If you have 2x120mm fans mounted in a space already, make sure there is some wiggle room because the radiator will definitely need it.
WVMountie07
217
