Will h100i work with LGA2011-3
OliverB360
33
I am preparing my next build and I want to reuse my h100i. I am looking at the EVGA x99 classy with the LGA2011-3. Will the included bracket for the LGA2011 on x79 boards work with the newer socket? I know there are changes to the socket but I don't know if the total dimensions change.
http://www.tomshardware.com/answers/id-1976870/lga-2011-backwards-compatible.html
This thread suggests that the LGA 2011, and LGA 2011-3 socket are physically the same size where dimensions are concerned. I can presume since there's no significant changes in size, only functionality, that a cooler designed for LGA 2011 should fit just fine.
If this were not the case you'd probably see a flood of LGA 2011-3 compatible coolers hit the market by now. The old 2011 socket CPUs didn't ship with stock coolers, so I can't imagine the new 2011-3 socket CPUs will either.
In any case since you've said you're recycling the H100i from another build, so what do you have to lose by...
In any case since you've said you're recycling the H100i from another build, so what do you have to lose by matching up the brackets?
