7 709zzy Honorable Jul 13, 2013 171 0 10,690 Apr 1, 2014 #1 I only have one case fan which is an exhaust fan in the back. My psu is on the top of the backside, and my case is only wide enough fit a tx3 cooler. Do you guys think h80i will fit? Also, is it enough for 8350? Here is my pc:
brarboy Honorable Jan 13, 2014 2,122 0 12,460 Apr 1, 2014 #2 Looking from Tech specs from both: Hyper TX3: Fan Dimensions: 92mm x 92mm x 25 mm Hydro Series™ H80i: Radiator dimensions: 120mm x 152mm x 38mm Fan dimensions: 120mm x 120mm x 25mm Upvote 0 Downvote
E Erman Yudhistira Reputable Feb 26, 2014 270 0 4,860 Apr 1, 2014 Solution #3 yes it will be fit if your rear fan is 120mm. Upvote 0 Downvote Solution
