Will have expansion slot brackets touching my motherboard be an issue
Personally i would not risk shorting my entire PC, as that is a lot bigger problem than airflow(which most likely wont cause a problem) and even if airflow is a problem, a piece of clear tape is a lot better solution.
it'll be a gaping hole in the side of my case... rip airfow
but really i dont want to take them out will it touching harm anything?
ill try to make sure they arent touching and if i cant do that ill just use the tape ty
