Will have my memory in slot 0 and slot 1 be better than slot 0 and slot 3 (present configuration)?
G
Guest
Guest
Hi, i have a Asus AMD motherboard M5A97 , i have 2 sticks of 1866 ram one in slot 0 and one in slot 3 , would it make any difference if i put the slot 3 stick into slot 1 , so that they work better together ? or will it make no difference ?? e.g slot 0 and slot 1 ?
cball1311
1,622
176
You want to have them in slots A2 and B2 (blue slots). If you have them in the A1 and B1 (black slots), it probably wont make a difference. The manual suggests A2 and B2 for 2 DIMMs but so long as you don't mix them like A1 and B2 or vice versa. You want to have them on similar slots to utilize dual channel access.
G
Guest
Guest
Hi , i have just checked my bios , i am in slot 1 and slot 3 , i think that means there in the same bank , as each slot is the same colour , e.g slot 1 is blue and slot 3 is blue...slot 0 is black and slot 2 is black.
Similar threads
