Will hd 7750 work on 300 watts ??
angel1059
6
Hello,
guys i am having
intel core 2 duo
1 hdd (160 gig)
no optical drive
2 gb ram
intel motherboard
will the card work fine on 300 watts
Yes it will if the psu actually outputs 300w.
Plz post your PSU brand and model.
Tom
I would say yes so long as the motherboard is PCI Express v1.1 compliant, vs the original PCI Express v1.0 spec.
- In v1.1 I believe they increased the power output that the PCIe x16 slot can output by +10 watts.
- Most HD7750's on the market don't require additional power.
- The 'newer' ones do, this has pros and cons.
What is the current video card in the system?
Does that card consume +/- 25 watts of a HD7750.
- If it does then there is a good chance it will work fine.
This card has a fairly good chance of working on a 300 watt PSU
http://www.gigabyte.com.au/products/product-page.aspx?pid=4131#ov
Hi again Angel - I didn't find a review for bestec 300w, but they had
a terrible review on an older 250w. Your's might be fine as HP
prob contracted somewhat better specs than the old
250w I found.
Bestec
MODEL WATTS PROBLEMS AND ISSUES REVIEWS
ATX-250-12E 250 Infamous for frying motherboards. Ancient ATX12V 1.3 design. 5VSB performance is awful. Below average build quality. jonnyGURU
So, use your gpu now, but start saving for an upgrade. You
won't need an expensive PSU, but a 350-430w from a quality brand
will give you peace of mind along with headroom.
Tom
