Question Will higher RAM work in system?
PH-Bench
42
I have a spec on a motherboard that states:
4 x DIMM, Max. 128GB, DDR5 6000(0C) / 5800(0C) / /
5400(0C) / 5200(0C) / 5000(0C) / 4800 Non-ECC, Un-buffered
Memory'
4 x DIMM, Max. 128GB, DDR5 4800 ECC Memory
Dual Channel Memory Architecture
Supports InteP Extreme Memory Profile (XMP)
I am looking at memory that states it is 6600. Will that be compatible? Thanks
Unlikely. 6600 is more than 6000 which is the board's maximum.
Check the manufacturer's QVL for memory compatibility and buy compatible RAM. The list is on their website.
