Will Hyper 212 Evo fit in Elite 335U?
For illustrative purposes only, this is how the Cooler Master Hyper 212 EVO CPU cooler would fit in the Cooler Master Elite 335U case (don't mind the very bad cabling and other components used, just how the CPU Cooler's height fits in the case):
Source: https://pcpartpicker.com/b/TN7hP6
Again, for illustrative purposes only, this is how the Cooler Master Hyper 212 EVO CPU cooler would look like when plugged on an MSI A68HM-E33 V2 motherboard (again, don't mind the other components and the case, just how the CPU Cooler will clear the...
It will fit in the case, but it will be very close, since Hyper 212 EVO is tall 159 mm and maximum cooler height in Elite 335U is 163 mm. Other parts matter too, cooler can block DIMM slots, so you will be able to use only low profile RAM, you won't be able to pull them out without pulling out cooler or won't be able to use some DIMM slots at all, but that is very rare.
Will block MSI - A68HM-E33 V2's though? I'm asking this for a friend and he really doesn't want to take risks.
Again, for illustrative purposes only, this is how the Cooler Master Hyper 212 EVO CPU cooler would look like when plugged on an MSI A68HM-E33 V2 motherboard (again, don't mind the other components and the case, just how the CPU Cooler will clear the motherboard's RAM slots and the actual RAMs):
Source: https://pcpartpicker.com/b/X48Ycf
