Solution aussithesham.business Feb 3, 2018 What kind of Fan Hub are you using? if it is one that would fit in an expansion slot with a lcd screen you would control it from the lcd screen.
aussithesham.business Prominent Jan 28, 2018 89 0 660 Feb 3, 2018 Solution #2 What kind of Fan Hub are you using? if it is one that would fit in an expansion slot with a lcd screen you would control it from the lcd screen. Upvote 0 Downvote Solution
