Okay, so basically I just moved back home after graduating college and I was able to live stream a little bit back at school since the connection was phenomenal but I'm not so sure if I will be able to at home.
This is my current connection speed:
http://www.speedtest.net/my-result/3522706024
I know that there are some streamers who stream in 720p with a 1.8 upload, my upload is just a little bit higher than that, but my download speed and ping aren't all that great so it has me a little worried. As far as my PC specs go I know that my PC can handle streaming but I will post the specs here anyways just so you all can get a clear handle of what I'm dealing with.
PC Specs:
GPU - AMD Radeon HD 7870
CPU - AMD FX-8320
MoBo - Asus Sabertooth 990fx R2.0
RAM - Dual Channel DDR3 (8GB)
Any help or advice is greatly appreciated. I hope to hear from some of you very soon
PC Specs:
CPU - AMD FX-8320
