Will I Be Able to OC & Would My System Bottleneck?
thekingpewe
39
So I have put together this pc parts list (which I most likely will end up buying) and I was wondering can I oc with this motherboard and will the gpu bottleneck the cpu. Btw I know you should even think of oc with the stock cooler, but could I get this from 3.4ghz to 3.5ghz? I dont really plan on oc right now but later on I will. Any problems you think I run into with this build? such as not enough power? The fact that the mobo has pci e 2.0 and the card has pci e 3.0?
Cpu- Amd Athlon x4 750k ($79.99)- http://www.amazon.com/Advanced-Devices-AD750KWOHJBOX-Graphics-Processor/dp/B009O412AU/ref=sr_1_7?s=pc&srs=2528920011&ie=UTF8&qid=1385694039&sr=1-7&keywords=amd
Gpu- Sapphire 7870 ($144.99)- http://www.newegg.com/Product/Product.aspx?Item=N82E16814202025
Ram- Kingston Hyper X 4gb ($34.99)- http://www.amazon.com/Kingston-1600MHz-Non-ECC-KHX1600C9D3B1-4G/dp/B0057Q4AGW/ref=sr_1_1?ie=UTF8&qid=1385838606&sr=8-1&keywords=4gb+ram
Hdd- WD Blue 1TB ($54.99)- http://www.newegg.com/Product/Product.aspx?Item=N82E16822236339
Mobo- Msi Socekt FM2 ($59.91)- http://www.amazon.com/MSI-Socket-MicroATX-Motherboard-FM2-A75MA-E35/dp/B009HP42HQ/ref=sr_1_1?s=electronics&ie=UTF8&qid=1385694557&sr=1-1&keywords=socket+fm2
Case- NZXT Elite 210 ($45.09)- http://www.amazon.com/dp/B005869A16/ref=twister_B007H5KNYO
Psu- Corsair 600 watts ($49.99)- http://www.amazon.com/Corsair-Builder-Series-Watt-CX600/dp/B0092ML0OC/ref=sr_1_3?ie=UTF8&qid=1385697511&sr=8-3&keywords=500+watt+psu
$469.95
Or Rebate with The Gpu
$454.95
For overclocking, I would change two things on your build.
First thing get a decent HSF like the cooler master hyper 212+/evo, something similar, or better.
Secondly get a motherboard that is meant for overclocking, by that I mean one with a large VRM and a decent heatsink on top of it.
Other than that it looks like a solid budget build.
Can I oc the cpu just 3.5ghz?
And if I can will it be a noticable difference.
Yes you should be able to, but it wouldn't make much of a difference in performance. I'd still highly recommend getting a better board so in the future you have the option to add a nice HSF and overclock farther than .1Ghz.
How about this Motherboard:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130709
Pros:
VRM heatsink
Newer chipset
cheaper than current option after rebate ($5 more without rebate)
Thanks, but I dont plan on OC, its just not in my budget :)
Thanks btw will any of these components bottleneck
That would depend on the game, resolution, and detail settings. For most games at 1080p you should be just fine. Tom's rates it as the best gaming cpu for that price range.
Here are a few threads to reference in regards to bottlenecks with that CPU:
http://www.tomshardware.com/answers/id-1750027/amd-750k-bottleneck.html
http://www.tomshardware.com/answers/id-1793766/7870-ghz-edition-bottleneck-athlon-750k.html
I have got a new thread on the forum, would you mind looking at it?
And btw thanks sooooo much for your help, its been really appreciated!
