Will i be able to play Assassin's Creed UNITY in Very Low settings ?
Abhraneel Roy
692
CPU-Intel Core i3 3210 3.2Ghz 4 threads , 2 cores.
GPU-Nvidia geforce gtx 650 1gb gddr5.
Ram-8gb
windows 7 64bit
Can i be able to run Assassin's Creed Unity in very low settings in 1366x768 resolution ?
I need a minimum of 15-25 Fps.
Will i get it in 1366x768 Resolution and in very low settings?
Hey I just received the product today.
After running assassins creed unity I am only getting 5-10fps.
Can anyone help me Please.
I have lowered the resolution to 1024x768 and changed the settings to very low but still I am getting 5-10fps. D
Help please
I have also upgraded the game version to 1. 4.
But stll 5-10fps.
Help.....
I unselected current 'solution' until we have figured this out, and perhaps get more people to help. Clearly there is something else going on here, you should not be getting only 5 FPS on the lowest resolution with that processor and graphics card.
Please open up your command prompt and type devmgmt.msc and hit enter, locate the Display tab and make sure that your GTX 650 is your primary graphics card. If it is then we can rule that out.
The GTX 650 is my primary graphics Card.
It is hard to believe that i am only getting 5-12fps in low settings and in that resolution.
Worst Framerates.
I should not be !
I should at least get 17-25fps.
I saw a video showing a GTX 650 1gb and 8gb ram and intel core i3 running assassin's creed unity and getting at least 15 fps minimum.
I dont know why it is happening !
Your are not alone my friend I have an AMD A8 5600k quad 3.6Mhz with Asus R7 260x but only 4GB of ram still I can't even get 30 fps on a windowed mode it's either AC unity is really a crappy game on PC or our system cant handle it
An a8 is extremely weak to run that game. I would expect it with your system, but not with his
right in the kokoro :'( well I only bought the APU since I'm a poor student my original plan was to get a fx 6300 and pair it with a nice GPU but sadly I made a big dumb mistake and bought an APU becuse it has a built in GPU or whatever you call it, still I'am able to play most of the latest games without a problem with my current build :) I'm just having trouble with AC unity :'(
