Will i be able to run cs:go with more than 100 fps
I was referring to the pc. The laptop is about equivalent (although gaming laptops are usually more expensive for the same performance compared to a tower). For the performance you want you probably want to get a higher end pc. A newer i5 and a higher end graphics card. It isn't awful but for the price 100fps on decent graphics is pretty high.
That PC can probably get pretty close to 100 fps on cs go with low graphics. What you have to remember is that the human eye can only take in so much and everything past 70is sort of useless. What you want to look at is high quality graphics. That card in that build should have no problem with some light cs go.
Well i can sure spot the difference between 70 fps and 100fps(i currently play with 70 fps on my laptop and its laggy) . Were you talking about the pc or the MSI laptop on my first comment?
