C Crinkling Reputable Jun 27, 2014 1 0 4,510 Jun 27, 2014 #1 I have a Dell XPS 8500 with intel i7 3.5 GHz processor, 8gb of ram, 2 tb of memory with a PCIe 16 slot. Will I have ANY kind of problems installing a GTX 750 ti graphics card in it?
Solution J J jaraldo Jun 27, 2014 This card doesn't need any 6pin connector and will work fine. EVGA GTX 750Ti Superclock http://www.amazon.com/dp/B00IDG3IDO/?tag=pcpapi-20
J jaraldo Honorable Mar 22, 2012 1,629 4 12,460 Jun 27, 2014 #2 The 750ti will only use around 75w at peak power. I'd say it will work. What case do you have? Edit: after a quick bit of googling, yes it will work. http://commweb-ps3.us.dell.com/support-forums/desktop/f/3515/t/19582165.aspx http://en.community.dell.com/support-forums/desktop/f/3515/t/19566737.aspx http://linustechtips.com/main/topic/144047-will-the-gtx-750-ti-work-in-dell-xps-8500/ Just make sure your power supply has a 6 pin connector or find a 750ti that doesn't need a 6pin. Upvote 0 Downvote
EasyLover Splendid Dec 30, 2013 6,551 0 24,960 Jun 27, 2014 #3 The Dell XPS 8500 has a 460-watt power supply it is plenty for GTX 750Ti. You should not have problems with that card's installation. Upvote 0 Downvote
J jaraldo Honorable Mar 22, 2012 1,629 4 12,460 Jun 27, 2014 Solution #4 This card doesn't need any 6pin connector and will work fine. EVGA GTX 750Ti Superclock http://www.amazon.com/dp/B00IDG3IDO/?tag=pcpapi-20 Upvote 1 Downvote Solution
Alex1357 Honorable Jan 13, 2014 56 0 10,640 Jul 7, 2014 #5 a gtx 750 ti can run off a toasters psu Upvote 0 Downvote
