[SOLVED] Will I be able to use Aura Sync fans if I only have "rgb strip" header
Jun 3, 2020
22
5
15
I've got some parts on the way, and I guess I could just wait until everything gets here and answer this question for myself, but I'm really curious. I Can't find the answer online anywhere.
I have an ASUS B360M-A motherboard that I got with a super cheap Mobo/CPU combo deal at Micro Center. I didn't even have a use for it yet, just grabbed it because it was a good deal.
And, a few weeks ago I back-ordered a Metallicgear Neo Air case which comes with 2 Skiron 120mm RGB front fans. (I also picked up another Skiron fan for the back). When I got word that the case was finally on it's way to me, I went ahead and bought all of the other stuff I need for a new build. Since I already had the Mobo and CPU just sitting here, I figured why not just use those. I didn't think to check if the motherboard had rgb headers for the fans until just now.
The motherboard doesn't have specific Aura headers but it does have a 12V 4 pin RGB header which they call "RGB Strip Header" in the manual. The fans all have 4 pin connectors as well. It seems to me you should be able to run the fan LEDs off this "strip" header, right? If I connect all my fans together and connect the main to the RGB strip header, Is that going to work? I'll find out in a couple of days, but I'm curious if anyone else has tried this.
The fans all have daisy-chained RGB cables, so I was assuming I could just connect them all together without the need for a splitter, right? Or, no?
