Question will i have enough power?
May 26, 2019
18
i have a evga 500w says 80 beside it i dont know what that means.
i plan to use components and not overclock really till i upgrade psu but might take a while the hardware im upgrading to is as follows:
2led fans
r7 1700 with stock cooler
gtx 1070 palit gamerock
msi b350 tomhawk
8gb 2400mhz corsair ram
cin19
a evga 500w says 80
It depends on the model, if it is the NI, WI, or B1. Recommend to buy other good PSU for the gtx1070. Also try to find the review for the PSU you are interested in. If you can't find any good for the PSU, don't buy it.
Or you list what budget you had, we may fine one for you.
