Will I need a full tower if im going to got 2 way sli in the future? Thanks!
Alex Kraus11
Commendable
Dec 6, 2016
31
My parts:
CPU- Intel Core i7-6700K 4.0GHz Quad-Core Processor
CPU Cooler- CRYORIG H5 Universal 65.0 CFM CPU Cooler
MOBO- Gigabyte GA-Z170X-Gaming 5 ATX LGA1151 Motherboard
Ram- G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory
Storage- Samsung 850 EVO-Series 250GB 2.5" Solid State Drive
Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
GPU- MSI GeForce GTX 1070 8GB Video Card
PSU- EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply
Thanks!
You can use a midtower instead of a full if you want to. You'll just want to make sure you pick one that can also support the cooler you're going to be using. The H5 has a 160mm CPU cooler height requirement which can be a problem for some cases.
That said, you're more limited by budget than availability.
These are all around the $70-$80
Fractal Design Define S
Fractal Design Define R5
Phanteks ECLIPSE P400
Corsair Carbide 400C
For the $90 to $100 something range
Corsair Air 540
NZXT H440
And obviously there are cheaper models out there, but these are pretty solid one to start looking at.
