Will i need my wireless lan in order to make my usb bluetooth work?
van4221
40
I have this thing and its blocking my graphic's card fan and i think removing it will reduce my gpu temperature's and its like really blocking the fan.. can i still connect my DS4 Controller without the wireless lan and my bluetooth usb will still work?
a wireless componene
you are talking about a wifi pci card
if the card has also a bluetooth adapter in it and you remove it, your bluetooth devices will not be able to comunicate with the pc via a pci card you removed
if the bluetooth is usb or in another card, or in the mainboard, it will keep working
A Wireless Lan component that i fit in my mother board.. since my mother board is so small and my 1050 ti is like a huge boulder while my wireless lan is blocking the fans. like its so close to one another barely touching the fans.
