I might be getting this computer soon, but it doesn't have that good of a graphics card. I will most likely upgrade it when I have the money. These are the specifications:
AMD FX-6300 3.5GHz
8GB DDR3 1333
500GB SATAII 7200RPM
Nvidia Geforce GT 610 1GB
Power Supply 500W
Link to the computer: http://www.newegg.ca/Product/Product.aspx?Item=N82E16883229362&cm_re=CyberpowerPC-_-83-229-362-_-Product
I will be getting a GTX 650 Ti Boost. (most likely) My question is, will I also need to upgrade my Power Supply? Thanks in advance.
AMD FX-6300 3.5GHz
8GB DDR3 1333
Power Supply 500W
