[SOLVED] Will i7-3770k work on joshua-h61-uatx (joshua)?
It should, yes. It supports the i7-3770. But if you are going for the ability to OC because it is a K chip, check to see if there are any OC options in BIOS. You might not be able to make use of the unlocked multiplier.
Latest posts
