will I7 4770 work on a Z68 motherboard ?
xphp
11
Hey guys
so i was wondering if an i7 4770 work on a Z68 motherboard with LGA 1150 socket ?
my motherboard is Asus P8Z68 deluxe, i know the motherboard is a bit old now but i was thinking of buying a new PC then i thought why not just upgrade my current system.
and if it works on z68 chips will there be any performance issues ? and is a 550w power supply enough for it + a gtx 970 ?
thanks a lot.
my current system is :
Asus P8Z68 deluxe
i5 2500k
corsair 8gb 1600hz ddr3 ram
550w power supply
670GTX
The i7-4770 is not compatible with the Asus P8Z68 Deluxe board. It's not listed in the compatibility table:
http://www.asus.com/Motherboards/P8Z68_DELUXE/HelpDesk_CPU/
sorry, i havent noticed that my motherboard is actually 1155.
so, do you recommend the i7 3770 ? since it is supported by my motherboard? is the upgrade from i5 2500k worth it ?
and will there be any performance loss because of the motherboard chip ?
thanks
