Question Will "ID COOLING FROZN A620" fit in a B450m Mortar Max mobo?
Sep 11, 2024
i tried to search if ID Cooling Frozn A620 cooler will fit in my b450m mortar max mobo in pangoly, but there were no results...
Somebody let me know if this particular cooler fits in my board.
If you don't have ram with tall heatsinks, the cooler should fit.
So less than 37mm's for your ram.
In fact if you look at their product page;
https://www.idcooling.com/product/detail?id=410&name=FROZN A620 BLACK
You'll see they're using DDR4 Kingston Fury Beast ram modules. Which are 34mm's tall;
https://www.kingston.com/dataSheets/KF432C16BB_8.pdf
What is the make and model of your case?
thanks for the reply, and i just looked up my Gskill Trident Z ram, and they're 45mm tall 💀
