Question Will Increasing Cpu Wattage Stop Frame Drops?
May 19, 2020
12
I have a fx 8320 and 1060 3gb Pc that I've had for a while now. I should be able to run CSGO and Valorant at 60 fps stable at lowest settings but the frames keep jumping up and down by a large margin ( from 120 to 40 then back up )
Could this be a wattage issue when it comes to the cpu and could increasing it in the bios fix the drops?
My PSU is an off brand 600w one with no 80+ .
Thanks in advance!
Thanks in advance!
Only "Wattage" problem could be because of motherboard and VRM not up to task.
