[SOLVED] Will Intel® Wireless-AC 9560 fit into my motherboard (Gigabyte B550 Aorus Elite V2 (rev. 1.0))?
kluader
27
I have connected a Samsung 970 Evo Plus 1 TB M.2-2280 NVME Solid State Drive already into my Gigabyte B550 Aorus Elite V2 (rev. 1.0).
This is my motherboard's page
https://www.gigabyte.com/Motherboard/B550-AORUS-ELITE-rev-10/sp#sp
I need to buy a Intel® Wireless-AC 9560. According to the product page, does it use minipcie?
I cannot figure out whether I can connect it to my motherboard.
https://ark.intel.com/content/www/us/en/ark/products/86068/intel-dual-band-wirelessac-8260.html
Sorry for the noob question
kanewolf
PCIE is almost always superior. They usually have an antenna(s) that can be positioned for best reception.
If the PCIe card has remote antennas like the Asus cards it would be the same or better. A PCIe card with antennas which are blocked by the PC case are not as good. USB adapters, that have two large antennas and include a base to allow you to optimally locate can be equal to PCIe. USB "nano" units are junk.
Reactions: kluader
it wont, uses different keying for it. better off with a pcie wifi :D
Reactions: kluader
kanewolf
Reactions: kluader
kluader
27
okay thanks, since I heard good things about intel, I consider to buy this one. It is pcie so it would fit my motherboard I think.
https://ark.intel.com/content/www/us/en/ark/products/99445/intel-wirelessac-9260.html
kanewolf
Reactions: kluader
kluader
27
But that isn't a product. It is a chipset. Just remember that antennas are more important than chipset. Intel, Realtek, could be good or could be terrible. Not because of the chipset or driver, but because of the antenna.
oh my bad, xD.
The tp link I mentioned earlier is a product? Can I buy it for my motherboard?
