Will Intel G4400 work with my VGA monitor?
AwesomeIronman
Commendable
Dec 24, 2016
13
I am gonna upgrade my PC with Asus H110M-E/M.2 motherboard
and Intel G4400 processor
I have samsung s19f350hnw monitor
on Intel's website ( https://ark.intel.com/products/88179/Intel-Pentium-Processor-G4400-3M-Cache-3_30-GHz ) > Graphics Specifications > Graphics Output - support for VGA isn't written
also > Max Resolution (VGA)‡ - here also any information isn't given
my monitor will be connected to montherboard via VGA cable
so will Intel G4400 processor work with it?
The Asus H110M-E/M.2 has a VGA port so obviously it's going to work 100% with a VGA monitor.
There is no issue there at all, I would agree an i3 6100 is definitely worth the extra money for mist people.
What are you actually upgrading from ??
You are aware you also need ddr4 ram for that board ??
MERGED QUESTION
Question from AwesomeIronman : "Will Intel G4400 processor work with my VGA monitor?"
Depends what your motherboard is, that has all the display headers on it.
I'd also HIGHLY recommend spending a tiny bit extra for an i3, it performs significantly better.
Save up a bit and get this.
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor ($109.99 @ Amazon)
Motherboard: MSI H110M Pro-VD Micro ATX LGA1151 Motherboard ($44.99 @ Amazon)
Total: $154.98
Generated by PCPartPicker 2016-12-24 08:39 EST-0500
Agree with Chugalug on the i3-6100 but more toward the vga support it doesn't. You may can find a motherboard with a digital to analog converter or buy an older cheap video card. It lookes like Chugalug motherboard has the converter so go with it for sure or get this video card.
http://www.anandtech.com/show/9483/intel-skylake-review-6700k-6600k-ddr4-ddr3-ipc-6th-generation/4?_ga=1.189759851.170017737.1475763383
Video Card: EVGA GeForce GT 710 2GB Video Card ($39.99 @ Jet)
Total: $39.99
Generated by PCPartPicker 2016-12-24 12:17 EST-0500
DO NOT get the GT 710, the i3's integrated GPU is actually more powerful.
If you're planning on gaming I can suggest a GPU for you.
ok so processor has nothing to with my monitor connected to motherboard via VGA cable, Thanks everyone
I am upgrading from (dont laugh or cry) Intel Atom D425 1GHz processor, Intel D425KT motherboard, 1GB DDR3 1333mhz (automatically underclocked to 800mhz) RAM and a nearly dead seagate 250GB 72000 RPM Hard Drive
My budget is tight only Rupees 12,000 ( $200)
so I am ok with pentium G4400
Yes, I am aware that I have to buy a DDR4 2133Mhz RAM stick
Very very thank you for your time
but sorry cause as i said above my hard disk is showing bad sectors and it has very limited space
the RAM is small type (maybe it is called SODIMM) so it wont work with new motherboards
anyways I have now decided that Intel G4400 processor is love, it is life 😛
I will buy only this processor
if possible please suggest a good, cheap motherboard for it having VGA port
and also a good, fast DDR4 4GB RAM stick
again sorry cause in my post I didnt had told that I also wanna buy a new hard disk
Update: so overall I wanna buy a new hard drive, a motherboard, a ram and processor
all at rupees 12,000 ($200)
ok ive chosen this parts to upgrade my PC :
Motherboard - ASRock H1110M-DVP ($55) ( http://www.newegg.com/Product/Product.aspx?Item=N82E16813157698 )
Processor - Intel Pentium G4400 ($64) ( http://www.newegg.com/Product/Product.aspx?Item=N82E16819117625 )
RAM - Corsair 4GB DDR4 CMV4GX4M1A2133C15 ($27) ( http://www.newegg.com/Product/Product.aspx?Item=N82E16820233770 )
Hard Drive - WD 1TB WD10EZEX ($50) ( http://www.newegg.com/Product/Product.aspx?Item=N82E16822236339 )
all cost $196
i am gonna purchase all this from my country india from local shops
what are your thoughts on this?
