will intel i5 work on ddr2 motherboard?
pratsss
7
I was seeing the general information of i5 and saw that it is compactible with DDR3-1066, DDR3-1333,which has confused me,as I have ddr 2 processor of intel.Please answer me as quick as you can.Maybe this is very easy question for you,but I am rookie in this things.
Manufacturer Intel Corporation
Model D945GCNL (LGA 775)
Chipset Vendor Intel
Chipset Model i945G
Chipset Revision A2
Southbridge Vendor Intel
Southbridge Model 82801GB (ICH7/R)
Southbridge Revision A1
BIOS
PCI Data
Slot PCI-E
Slot Type PCI-E
Slot Usage Available
Bus Width Unknown
Slot Designation PCIE X16 SLOT
Slot Number 0
Slot PCI-E
Slot Type PCI-E
Slot Usage In Use
Bus Width Unknown
Slot Designation PCIE X1 SLOT 1
Slot Number 1
Slot PCI
Slot Type PCI
Bus Width 32 bit
Slot Designation PCI SLOT 1
Slot Number 2
Slot PCI
Slot Type PCI
Bus Width 32 bit
Slot Designation PCI SLOT 2
Slot Number 3
I just cant say about the same socket now and this is the one I am thnking to buy http://www.flipkart.com/intel-core-i5-2310/p/itmdcvv2muy8sjqr?pid=PSRDCVQGYZFNTF6Q&ref=1875c51f-77f7-459d-8f9f-84f3d4302f79&srno=t_3&otracker=from-search&query=i5
They mean that NO i5 chips have ever been made for LGA 775. They had LGA 1156 1155 1150 ect, but never 775
The i5 cpus also have a built in memory controller so they will only take DDR3. The best you can get is a core2 quad for LGA 775.
If you want to run an i5, you will need to tell us what I5 it is because they have had multiple sockets. For example, I have and older lga 1156 i5 750 in my media center. It needs a board that is LGA 1156, while a i5 2500 would need an LGA 1155 board to work(they do not even fit in the wrong boards.)
If you tell us what cpu you have or want to use, we may be able to fine a board. You WILL need to move to DDR3 for the i5 cpus.
Cheapest I see on that website would be this
Gigabyte GA-H61M-DS2 - Rs. 3180
It is important to know that a video may cover 2 of the 4 sata ports(this could be an issue for sure.) You only get 2 ram slots(may not even be an issue). Even the first versions of that board FULLY support your cpu.
For a bit more you can get this
Gigabyte GA-H61M-D2H - Rs. 3438
Better sata port placement and 4 memory slots. This board should also have no issues with your cpu.
Either way, remember to pick up some new DDR3 memory.
As Tradesman1 says, any LGA 1155 board will work with that cpu(being as LGA 1155 was introduced for the second generation i7/5/3 cpus).
