Hello all. I just had a couple really quick questions. Number 1: I have a CM HAF 912 case and am installing an FX 8350, CM Hyper 212 EVO CPU Cooler and 8 gigs of DDR3-1600 Corsair Ballistix Sport RAM. Will there be any problems fitting that on the board? Should I worry about clearance issues? Also, does anyone have a really good YouTube video you would recommend for a tutorial for this build? The MOBO is a Gigabyte GA-990FXA-UD3.
Number 2: DO I need to apply thermal paste to the CPU or is it usually already applied? If I do have to, what is the most recommended way?
Thank you all and best wishes to responders!
Danny
Danny
