Will it be okay if I add another 4GB kit on my PC
haydar_ai
Commendable
Oct 12, 2016
4
Hi, I currently have 2x2GB OCZ DDR3 kit and planning to upgrade it to 8GB. Is it okay if I add another 2X2GB kit on my 3rd and 4th slot?
2x4GB is the best bet - there are no guarantees when 'adding' additional DRAM that it will even play with the old DRAM. With the old, 2x2GB of OCZ you may have a mobo that isn't even compatible with today's DDR3 - is the mobo an older model 1156, 1366, 775?
It's an AM3+ motherboard
