Will it fit - case for my i7 7700K PC build
yonielbz
CPU: Quad Core i7 7700K Kaby Lake 4.2Ghz S1151
CPU Cooler: Noctua NH-D15
Motherboard: Gigabyte Z270P-D3
Memory: 16GB Crucial Ballistix-Tactical DDR4 3000Mhz CL15
Video Card: ASUS Nvidia GeForce GTX1080Ti 11G D5 STRIX OC
Storage 1: SSD SanDisk PLUS 240G SATA III
Storage 2: Seagate 2T 3.5'' Sata3 Barracuda 7200RPM
Power Supply: Seasonic X-Series 650W GOLD Modular
Network Adapter: TP-Link PCI-Express TL-WN881ND 300Mbps
Will this fit in the CoolerMaster MasterBox 5 Black ?
I just want a case without tempered glass that has decent cooling and I am at a loss with all the options.
FYI: The cases available to me are limited - mainly from: CoolerMaster, be quiet!, Antec, Zalman and Corsair.
Thanks for the help!
Yes this will all fit happily in the CoolerMaster MasterBox 5. The Strix will also fit. The Cooler master case is a good alround option.
the only slight issue will be the ram clearence for the Noctua...though the RAM is quiet low profile so it should be okay, you may have to move the noctua fan slightly higher..
Someone asked the question here regarding the noctua and the MAsterbox 5:
http://www.tomshardware.co.uk/answers/id-3317445/master-box-noctua-d15.html
Thank you for the reply vMax!
Do you by any chance know if the Cooler Master Master Case 6 PRO is a better fit for my build?
Great, Thanks for the help! :)
