Will it fit - CPU Cooler for Prebuilt HP Desktop
SpetsnazBeaver
142
Hi guys. Well, my prebuilt HP's CPU cooler up and died and I need a replacement. I'm not a pro at upgrading, having only upgraded a GFX card and PSU once. Its a mid ATX with dimensions 40 cm (H) x 17.78 cm (W, this being the "height" for cooler) x 43.18 cm (L). Here's the specs page for more detail: http://support.hp.com/us-en/product/HP-Pavilion-Elite-e9200-Desktop-PC-series/3999455/model/4041160/document/c01901297/
The cooler needs to be socket LGA 1366, 4 pin and 92mm (the 120mm are just too big). The old cooler was 135 mm (H) x 95 mm (W) x 93 mm (L). So, these are the coolers I've narrowed down to:
SilverStone Argon Series AR02: http://www.newegg.ca/Product/Product.aspx?Item=N82E16835220061
Enermax ETS-N30-HE Twister: http://www.newegg.ca/Product/Product.aspx?Item=N82E16835214054
Cooler Master Hyper D92: http://www.newegg.ca/Product/Product.aspx?Item=N82E16835103108
Rosewill RCX-ZAIO-92: http://www.newegg.ca/Product/Product.aspx?Item=N82E16835200056
I am totally sold on the Cooler Master but afraid it might not fit in the case. Measuring the inside from the moterboard to the side panel I would have 2-3mm to spare but irl I'm not so sure. I want a powerful cooler for peace of mind, oc capability and transferability to a new build a few years down the line so I want something around 50 CFM +/- 5 CFM. Do you think the Cooler Master will fit? If not, which of these other ones should I get and are they even any good? Feel free to suggest other coolers of similar size and power too. I'm Canadian so Canadian friendly vendors would be appreciated.
The cooler I have has the fan in the middle. I coudn't find too much specs on the fan except that it's 92mm, 12V, 0.41A. No idea what cfm I would need. It's some manufacturer part fan I can't find new: avc ds09225r12hp032.
I don't have a problem with buying a new cooler in the $30-50 range though. I definitely don't want to go improvised with zip ties.
So I assume you can't buy cpu specific fans separately? Can you help me out then with the original question? Will the Cool Master fit and if not, which cooler should I get? The cooler height is the only limitation, the cpu area is fairly clutter free and spacious.
What you are looking for are "92mm PWM-Controlled Fan "4pin" which are all case fans by BTW google that for the specific model you wish. I replace all the stock Cool Master fans with these since they last longer and are quieter.
ARCTIC F9 PWM Rev. 2 Fluid Dynamic Bearing Case Fan $7.5
43 CFM at 23.5 dBA
http://www.amazon.com/ARCTIC-F9-PWM-Rev-Dynamic/dp/B00H3SVWF4/ref=sr_1_1?s=electronics&ie=UTF8&qid=1427265275&sr=1-1&keywords=92mm+PWM-Controlled+Fan
Avoid Masscool, Logisys fans of this size they seem to not last to long at least from my experience.
Higher CFM fans will be much more noiser, 50+ CFM will be 35-50 dBA.
So I''m making some progress searching for a fan instead of buying the whole cooler and have found a nice range of 92x25 4 pin fans. I have noticed some of those fans require more than the 0.4A my old cpu fan needed. Others are close at 0.38A. Should I get the ones closer to 0.4A? Also, is frozencpu a reliable vendor? Heres a list of what I have found by order of decreasing CFM.
Delta: http://www.frozencpu.com/products/9320/fan-580/Delta_90_x_25mm_High-Speed_PWM_Fan_-_10259_CFM_AFC0912D-PWM_.html?tl=g36c365s940
BGears: http://www.frozencpu.com/products/11893/fan-778/BGears_B-Blaster_90mm_x_25mm_3500RPM_High_Speed_Fan.html?tl=g36c15s59
Cooljag Everflow: http://www.frozencpu.com/products/5878/fan-293/Cooljag_Everflow_90mm_x_25mm_PWM_Fan_F129025BU.html?tl=g36c365s940
Scythe Kama: http://www.frozencpu.com/products/21911/fan-316/Scythe_Kama_92mm_x_25mm_PWM_Fan_DFS922512M-PWM.html?tl=g36c365s940#blank
Rexflo: http://www.frozencpu.com/products/5776/fan-287/Rexflo_92x92x25mm_PWM_Fan_-_DF129225BH-PWMG.html?tl=g36c15s59
Cooler Master: http://www.newegg.ca/Product/Product.aspx?Item=N82E16835103070&cm_re=pwm-_-35-103-070-_-Product
Evercool: http://www.frozencpu.com/products/11295/fan-722/Evercool_Long_Life_92mm_x_25mm_PWM_Fan_EC9225HH12BP.html?tl=g36c365s940
My Cad system is running a I7 980X @ 4.4ghz and I have two of these fans in a Push Pull config using a Coolmaster TX3, the Temps are acceptable considering the piss poor air flow in the Desk the Case is enclosed in. I have used higher CFM fans but the noise was always annoying, these give me acceptable cooling and low noise. This system also never powers down and I have been using this config for 1 year now. 8000+ hours on a pair of $7 fans seemed pretty impressive to me I have paid 3X more for expensive fans that died or became noisy at around 6 months of constant use. Noise is a big factor to me, my office is small and load fans are hella annoying.
