Will it fit in my case?
armin23
I've got a SAPPHIRE 100283-3L Radeon HD 5770 in my cart along with a Rosewill R102-P-BK Micro ATX Case.
Will the card fit in the case?
EDIT: Also, I'm wondering if it will fit in my mobo. ASUS M4A785-M AM3/AM2+/AM2 AMD 785G HDMI Micro ATX AMD Motherboard
The length of an ATI radeon HD 5770 video card is 8.5 inches (216mm).
The length of the micro-atx case is 15 inches (381mm). It will be a tight fit but the 5770 video card will fit inside your pc case. The front edge of the card will probably be right up against the drive cage and the power cables will probably extend into the drive cage.
The video card will also fit your motherboard.
