Will it fit in my case?
Yes it will fit. Two fans are there with this case. 6 fan is overkill. Max two fan intake and max 2 fan exhaust is just more than enough. Anything more will not give you any note worthy benifit. Check this,
https://www.youtube.com/watch?v=8OmkmluAYAQ
This mobo has,
- 1 x CPU Fan Connector (4-pin)*
- 1 x CPU/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)**
- 2 x Chassis/Water Pump Fan Connectors (4-pin) (Smart Fan Speed Control)***
*The CPU Fan Connector supports the CPU fan of maximum 1A (12W) fan power.
**The CPU/Water Pump Fan supports the water cooler fan of maximum 2A (24W) fan power.
***The Chassis/Water Pump Fan supports the water cooler fan of maximum 2A (24W) fan power.
This mobo has,
