Will it fit my in my Cabinet
Rohan Rathi
83
Will a Cooler Master Hyper 212 Evo fit in my NZXT Guardian 921 RB without removing the side fan?
The PSU is bottom mounted and the motherboard will be mounted above it so the 212 Evo will be near top inside the cabinet, the side fan on the Guardian is at the middle of the cabinet at the side panel.
chulex67
801
89
No, You have 144mm with the fan mounted, Without the Fan mounted you have 170mm, The CMH 212 Evo its 159mm tall, so it wont fit without removing the Fan.
Go To Neweeg, click the heatsink you are interested , go to Details and Read Heatsink Dimensions.
Similar threads
