Will it fit??
The dimensions are for outside of the case, so it will be shorter in inside. And don't go with that case, no way it can fit the card.
Look for a standard ATX mid tower case, atleast 19/20" in length.
If i get a different case won't i have to change the motherboard also? What motherboard/case would you recommend? Im looking for the cheapest build possible so anything would be appreciated
