Will it fit
Mitx uses 4 of the same mounting holes as atx/mATX, so physically it will mount into any ATX case. It would have problems in my define r5, but that's only because the lower right Mitx hole (center hole for atx) happens to be an alignment pin, not a hold down screw.
So yes, it'll fit in that case.
I've not seen this case personally, but it does say micro ATX for mobo compatability, whereas the mobo chosen is mini itx. And that's from cougar website. Don't think it'll work right. ATX and itx are 2 different standards when it comes to board sizes and layouts.
