K kevinxia159 Honorable Sep 4, 2012 53 0 10,630 Feb 4, 2016 #1 Will this GPU fit into a Dell Inspiron 570? http://www.amazon.com/gp/product/B00KJGYOBQ?keywords=video%20card&qid=1454609659&ref_=sr_1_3&s=pc&sr=1-3
BadActor Expert Ambassador Oct 31, 2015 8,749 1 54,965 Feb 4, 2016 #2 Should work fine. The board is fitted with an optional PCIe discrete graphics card slot and has a 300 watt PSU. Upvote 0 Downvote
Rogue Leader It's a trap! Moderator Dec 22, 2014 33,378 3,242 116,640 Feb 4, 2016 #3 Yes that will fit fine. As for it working there is a chance it will not as some Dells have issues with some GPU's. You may want to try looking it up on the Dell forums to see what others have used. That said Amazon has a good return policy, so worst case you can return it. Upvote 0 Downvote
SPgamer007 Honorable Nov 17, 2013 1,630 0 12,460 Feb 4, 2016 #4 Yes,it will fit as your case is not a slimmer one. Also,I'd advise you to get a GTX 750ti, costs about the same but performs better. http://www.amazon.com/dp/B00IDG3IDO/ref=psdc_284822_t1_B00KJGYOBQ 110$ Upvote 0 Downvote
