Will it fit?
pieshower
Commendable
Jun 6, 2016
I am upgrading to liquid cooling and was wonder if a h110i gtx will fit in my current build.
Build:
Corsair 200r case
970 gaming motherboard
Basically I want to know if my motherboard won't get in the way of the radiator and fans. I feel as if one of the top heatsinks is going to get in the way. So, will it fit?
Edit* Also with the same motherboard, will it fit in a Corsair Obsidian series 450D?
It will fit in both as they both support ATX and your mobo is ATX, but you will have a little more room in the 450D. 200R will be tight and require you to choose components wisely.
Ok, thank you. New question: The h110i gtx says it's only compatible with AM3, the mobo is an AM3/AM3+ socket, will it fit into the socket without modding? Basically, will I be able to screw it down into my motherboard and it actually be the proper way to do it?
Edit* Sorry I'm new to this. Just want to make sure everything works before I buy it.
