Will It Fit?
loggand
Commendable
Oct 22, 2016
7
Would all these be compatiable in my case and together (will it fit)?
Case: Cooler Master MasterBox 5 Case Black Edition - https://www.scan.co.uk/products/cooler-master-mcx-b5s1-kwnn-11-masterbox-5-black-edition-mid-tower-case-side-window-headphone-mic-in
Psu: Cooler Master 850W - http://www.coolermaster.com/powersupply/v-series-psu/v850/
Motherboard With Cpu: Z170-Gaming K3 & Intel Core i5-6600K 3.5GHz Quad-Core Processor - https://www.overclockers.co.uk/gigabyte-z170-gaming-k3-intel-core-i5-6600k-bundle-10-pounds-saving-bu-026-gi.html
Cpu Cooler: Cooler Master Hyper TX3 EVO Cooler - https://www.scan.co.uk/products/cooler-master-hyper-tx3-evo-cpu-cooler-92mm-fan-for-intel-amd
Ram: Corsair Vengeance LPX 16GB DDR4 Memory Kit Black - https://www.scan.co.uk/products/16gb-(2x8gb)-corsair-ddr4-vengeance-lpx-black-pc4-19200-(2400)-non-ecc-unbuffered-cas-14-16-16-31-xm
Gpu: Gtx 970 Mini Itx - https://www.scan.co.uk/products/4gb-gigabyte-geforce-gtx-970-mini-itx-oc-gaming-pcie-30-7000mhz-gddr5-gpu-1076mhz-boost-1216mhz-core
should fit - but why do you get a Mini-ITX card?? this card will be slow and hot compared to a regular sized one.
depending on your budget go with the 1050Ti released next week or a Rx480
a 850W PSU is severe overkill unless you plan on getting 2xGTX1080+an i7
550W can handle any single GPU setup.
if you can get a better cooler like a Cryorig H7 (not if it costs 100pounds)
