A Apostolos12345 Prominent Feb 19, 2017 1 0 510 Feb 19, 2017 #1 Will an MSI GTX 1070 Gaming X fit in my Coolermaster K380 case? I want to know if someone has tested it and fits in length and width. Thank you!
Solution COLGeek Feb 19, 2017 See here: http://www.coolermaster.com/case/mid-tower/k380/ And here: https://us.msi.com/Graphics-card/GEFORCE-GTX-1070-GAMING-X-8G.html#hero-specification Max length for slot 1 (the one normally used) is 279mm. Length of GPU: 279mm. That is an awfully tight fit.
COLGeek Cybernaut Moderator Apr 6, 2009 59,538 5,298 184,340 Feb 19, 2017 Solution #2 See here: http://www.coolermaster.com/case/mid-tower/k380/ And here: https://us.msi.com/Graphics-card/GEFORCE-GTX-1070-GAMING-X-8G.html#hero-specification Max length for slot 1 (the one normally used) is 279mm. Length of GPU: 279mm. That is an awfully tight fit. Upvote 0 Downvote Solution
