D Dorksouls Reputable Jul 13, 2015 50 0 4,630 Nov 29, 2015 #1 already have ram but will it work: https://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=522354&action=wish_lists
Solution migronesien Nov 29, 2015 Yes, it will. But Corsairs VS series isn't really recommended, because it's on the low end side of PSUs and isn't THAT safe to use on a gaming system. I'd choose any tier1/2 PSU from this list: http://www.tomshardware.co.uk/forum/id-2547993/psu-tier-list.html Just search one up on the site you're using. tier 3 is also okay, if you're on a tight budget but i wouldn't go for a tier 4 PSU.
migronesien Honorable Jun 3, 2015 1,270 3 11,965 Nov 29, 2015 Solution #2 Yes, it will. But Corsairs VS series isn't really recommended, because it's on the low end side of PSUs and isn't THAT safe to use on a gaming system. I'd choose any tier1/2 PSU from this list: http://www.tomshardware.co.uk/forum/id-2547993/psu-tier-list.html Just search one up on the site you're using. tier 3 is also okay, if you're on a tight budget but i wouldn't go for a tier 4 PSU. Upvote 0 Downvote Solution
