Will It Work?
IIMurderMuchII
Commendable
May 23, 2016
5
So i have been making endless gaming builds on pcpartpicker and other websites, but I have found the build I have been waiting for (I think...). I know a bit about computers, such as how to build them and what is compatible with what and such, but I need some advice for this build,
My Build - http://pcpartpicker.com/p/9sPscc
All i'm wondering if these parts will successfully run the forest, Black ops III and Minecraft with shaders at high settings 60 fps. ( if not 60 then maybe 45 )
I am open to suggestions of computers that will operate even better for around 400 - 450 dollars. Thankyou!
It looks all right for a very low budget system, the problem I'm having is I don't play any of those games so I can't tell you how good it will be at them, I can offer some advice though, get two sticks of memory over one big stick, and make sure it's a set, it'll run quite a bit faster in dual channel rather than single channel. Two, don't skimp on a PSU, you may think you're saving yourself a few bucks, but it can put a lot of undue stress on the rest of the components, and instead of upgrading when you want to you may be upgrading out of necessity. I'm not familiar with that PSU, so you may have a good one, check around here for the tiered list of PSUs, I know we have one, try to stick with tier one or two, three if you have to, stay away from four or five. If you can float it, get the best video card you can afford, again, check here for the tiered list (it's at the end of the best video cards for the money article...) the 750Ti is really good for systems with low wattage PSUs, but there are faster cards out there if you have the watts.
Here is the build that you have better chances with:
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor ($110.99 @ SuperBiiz)
Motherboard: MSI H110M Pro-VD Micro ATX LGA1151 Motherboard ($49.99 @ Micro Center)
Memory: Crucial 8GB (1 x 8GB) DDR4-2133 Memory ($26.99 @ SuperBiiz)
Storage: Hitachi Deskstar 7K2000 2TB 3.5" 7200RPM Internal Hard Drive ($56.95 @ Amazon)
Video Card: EVGA GeForce GTX 960 2GB SuperSC ACX 2.0+ Video Card ($163.98 @ Newegg)
Case: Raidmax EXO ATX Mid Tower Case ($19.98 @ Newegg)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply ($29.99 @ NCIX US)
Total: $458.87
Generated by PCPartPicker 2016-05-24 01:11 EDT-0400
Thankyou! This helps a lot
Not with that case and PSU you don't.
