[SOLVED] will it work?
thekillerx10
538
38
10,990
so i was wondering if a xeon e3 1240 v2 work on an asus p8z77-v lx but this cpu is not listed on the cpu support list but it use the same socket and there is other motherboards with the same chipset have it listed so will it work?
EDIT****I didn't see those few Xeon's listed towards the bottom. It may work it may not. The E3 1230 and E3 12 45 is supported but it doesn't mention the E3 1240. Only real way to know is to flash the BIOS to the most recent update and try it.
Follow the link I posted earlier, it's a CPU Z validated screenshot which means it works and should also work for the OP.
so the xeon will not work
Intel Xeon E3-1230 (3.2G,1333,L3:8MB,4C,D2)ALL0610GO*Since Xeon CPU is not desktop CPU model, some feature may not able to work on this combination. For detail, refer to support.asus.com
Intel Xeon E3-1230 v2 (3.3G,L3:8M,4C,HT,69W)ALL0610GO*Since Xeon CPU is not desktop CPU model, some feature may not able to work on this combination. For detail, refer to support.asus.com
Intel Xeon E3-1245 v2 (3.4G,L3:8M,4C,HT,77W)ALL1201GO*Since Xeon CPU is not desktop CPU model, some feature may not able to work on this combination. For detail, refer to
I'd say it's possible since a 1245 is listed to work
I would say yes.
Intel Xeon E3 1240 v2 @ 3618.49 MHz
Dump [llruj9] - Submitted by PC-20180306THJY - 2018-08-19 03:42:14
Latest posts
