Z Zanarisrobo Honorable Dec 25, 2012 27 0 10,530 Oct 6, 2013 #1 Will the picture quality be good if i use mini displayport-hdmi cables on a triple monitor setup? The monitors are benq gl2450hm and the GPU is a Gigabyte radeon 7990 6gb
jacobnestell Distinguished Oct 6, 2013 195 0 18,760 Oct 6, 2013 #2 mini display ports will work fine the max resolution they support currently is 5760 × 2160 so if you have monitors higher then that your out of luck Upvote 0 Downvote
N noidea_77 Distinguished Jul 28, 2012 6,523 0 19,960 Oct 6, 2013 #3 It's a digital connection and dp-to-hdmi is basically only wiring, nothing is converted. So the quality will be as good as the monitor displays it. Upvote 0 Downvote
