G
Guest
Guest
1) Would it be causing any performance issues like sudden FPS drop or low FPS as compared to high end boards like Z170s?If so then how much ? (Around 2fps?)
2) Will there be any overheating issues with the motherboard at stock clocks?
3) Also if I try to OC the CPU through baseclock to 3.8 GHz and the GPU to 1500MHz (Core),will this MOBO be able to cope up with that?
