Question Will my 600w psu be powerful enough for my build?
Aug 16, 2019
Hi, first time posting here, I'm currently in the process of buying the parts for my new rig, I can't find much info about how many watts my mb needs and I'm worried my psu won't have enough power to give it.
Here's the parts:
Motherboard - ASRock B250M-HDV
GPU - Geforce GTX 690
CPU - i5-7500
RAM - Corsair Vengeance LED 16gb (2x8gb), DDR4 2400mhz
HDD - Western Digital WD10EURX 1TB, 64MB Cache
PSU - Cooler Master MWE 600w, 80+ Bronze
Thanks!
gpu ~ 300 W
CPU ~ 65 W
rest ~ 50 W
415 + 20% headroom, 550+ good quality is recommended. However, MWE is not good quality unit. If you have it already, you may use it but pls plan to upgrade in the near future.
Aug 16, 2019
gpu ~ 300 W
CPU ~ 65 W
rest ~ 50 W
Ah, thank you, I am planning on upgrading it.
edit: No, I haven't bought it yet, I think I'll buy one from evga
PC Tailor
Dignified
Herald
As I'm sure it's leading up to it, just remember a good brand does not mean it's good quality.
EVGA make plenty of poor units.
The CM MWE 600W isn't too bad at that wattage, the lower wattage units aren't so good. But the higher wattage are decent enough budget ones (age permitting!). I'd still always opt for higher quality, but it's not awful from my understanding, but there are plenty better.
