I have a Core i7-7700K that needs some heavy cooling after I just realized that the Cooler Master 212X Turbo (which should have been enough cooling for the cpu) just couldn't take that 87 degree load that I put on the processer (from AIDA64 feeding it full of data until it literally burned).
I was wondering if the Corsair H100i V2 was small enough to fit inside the (probably non-water cooling support) Corsair 100r Tempered glass case.
My dad loves to save a few buck or 100, and he was wondering if it could fit.
He also wanted to ask tigerdirect if it could fit, which is a complete ripoff on Newegg. Then he wanted to ask Newegg, but Newegg dose'nt deal with this type of problem (as far as I know).
The only option we can see is either risk putting in a radiator that is a few mm off, or buying a case that is perfectly designed for this, and can well fit my system. Please help me.
