[SOLVED] Will my asrock a320m mb be compatible with my incoming gtx 1070?
May 13, 2020
12
I have looked up and gone to multiple sites to find an answer but I’ve seen both that it’s not compatible and that it is, I just need a clear answer. Help needed, please!
Absolutely compatible. Mobo - GPU compatibility is rarely a concern if you've got a <10 year old Asus/MSI/Gigabyte/AsRock/Biostar/EVGA/etc common non-OEM brand mobo.
What PSU do you have?
What case? (does the case have enough length/height inside the case for the GPU you're using)
My case is fine, I have a 600w psu
Should I get a new psu? My psu I have now is a year and 2 months old
